Old 11th June 2024, 07:36 PM
Fredde Fredde is offline
Front seats would normally be a straight swap on a FL as they should all include airbags and rear footwell lights.
Assuming you're RHD, and these being from a LHD ? car though you will have to watch out for whether your new drivers seat has memory function, and airbag system may complain if the new passenger seat has no occupancy sensor, which I guess it wont have.
In the rear, again subject to you already having airbags etc, then its a fairly easy install but you'll need to supply some +12 into the rear seats for the lumbar / headrest to move. If you want the full oem look, you need to run a wire to the front for the headrest lowering switch too. Heating is a bit more complicated, but runs from the fuse box in the right hand side of the boot, into the switches in the back of the center console and back to the rear seats.
I'm assuming you've matched swb/swb or lwb/lwb as the recline angle of the LWB is different to the SWB and they seats wont fit properly without some mods in the rear if you mismatch.....
Edit: Just seen you're in Norway, so that the RHD/LHD bit covered, but I've left it in as advice to anyone else considering an import
Hello I have a lwb with the standard rear electric seats and I am swapping to sports electric seats from swb s8 is the difference in the seat base that moves or the actual cushion? What would the mods needed to make it work be?
D2 A8L 4.2 AQF 4.2 LZ9W Ebony Black Pearl Fully electric rear seats D3 s8 front brakes s8 mirror housings 18x8 Avus 3 winter wheels PDC rear blinds Nav Electric steering wheel adjustment TPMS Leather pack 1 with retrofitted stitched leather lower dash panels folding auto dimming mirrors solar sunroof cold weather package CD changer double glazing all around memory seats passenger seat adjustment from rear seat Bose servotronic xenon plus headlights
C5 Allroad 4.2 BAS 4.2 LZ6G Irish Green Metallic Bose RNS-E Rear Blinds folding auto dimming mirrors Heated MFSW with shift buttons PDC Recaros heated seats all around CD changer Nav
B5 A4 STCC Edition AJL 1.8T Quattro Built engine GT28RS maxxecu Remote locking Trip computer Sport seats Eibach/Bilstein suspension Flexfuel
C5 A6 1.8T Quattro AWT 1.8T Reliable, unlike the others
Previous Audis B7 S4 Avant B5 A4 Avant 1.8T B8 A5 SB 3.0tdi C5 A6 1.8T C5 Allroad 2.5 TDI
Old 12th June 2024, 10:48 AM
According to the parts catalogue, the base section (#5 in the attached image) is different in the LWB model.
The part numbers for the SWB model are 4D0885305A (left) and 4D0885306A (right), and the part numbers for the LWB model are 4D0885310 (left) and 4D0885311 (right).
Solely based on what the parts catalogue shows, in theory it should just be a case of swapping the base section over... in theory.
Name:	Screenshot 2024-06-12 114308.png
Old 12th June 2024, 08:47 PM
Thanks a lot i didn’t even think about checking the catalog.
