Old 4th December 2024, 04:16 PM
Thanks Sean. MJ did mine the last time and she's obviously an expert at that job.
Previously I had a local VAG specialist do it and printed off those exact Audipages instructions to assist them.
Old 8th March 2025, 06:29 PM
And sod's law has struck again! The dreaded gearbox lights of doom appeared this evening on the way home, after I stopped briefly then reversed couple of feet to get space to drive off!
After I stopped again, turned the car off fully and restarted I could see the "D" symbol red background was flickering on and off intermittently, though when I went into Sport mode that stayed on solidly as normal, so I guess I can use it like that for a while... (fingers crossed).
I might try and see if it's useable in Tiptronic mode as I also have the steering column switches to make that easier to use.
My biggest problem, assuming I can get a new F125 switch, is finding somewhere competent to change it that's within a reasonable distance of South Bucks.
Old 8th March 2025, 07:25 PM
Don't assume it necessarily needs replaced.
Have you been using the car much recently? My recent experience over the last couple of years is that it can show the dreaded red PRNDS once in a blue moon, and that can disappear completely if the box is "actively used" via the stick shift or the paddles.
Though I think you may use yours more than I use mine...
Old 8th March 2025, 07:34 PM
I'll see tomorrow, but I have been using it occasionally.
It's definitely NOT detecting the D position properly (or at all most of the time) and that also looks as if it stops you using Tiptronic. It will currently go into S mode though.
I'll have a look at my diagrams of the innards and see if I can figure out the likely problem/breakage, but realistically I think it will need replacing.
Old 8th March 2025, 08:00 PM
I've got a busy day tomorrow as its my granddaughters 2nd birthday. But if I get a few minutes I'll plug VCDS in and see what contacts are operating as I move the stick - details on how to do that are in this post I made in 2020 with relevant information throughout the thread https://forum.a8parts.co.uk/showpost...0&postcount=23
First thing I'll do is see what code it's signalling when D is selected but D isn't highlighted on the DIS but I'll check all the stages.
It should start at 1000 for P then briefly 1100 (Z1) as it moves to R (0100) and 1100 (Z1) again as it moves to N (1110).
After N (1110) its then 1010 (Z2) in transit to D which should be 1011 and finally 0111 when in S.
(There can also, looking at the tracks, theoretically be a 1111 code between D and S.)
Old 9th March 2025, 09:31 AM
Well I did that and everything seems to be working normally. I did of course have stored codes for implausible F125 signals in the Gearbox and ABS ECUs.
After a fair amount of wiggling of the shifter to try to look at "transitional" signals I did manage to trigger the red lights, but they went away on an ignition cycle, everything still looked OK and I couldn't recreate it.
I do wonder if there's a bit of "crud" in there that has just moved out of the way? I'll use the car locally for a while and see what happens.
Old 9th March 2025, 10:09 AM
PROGRESS! Of sorts -----
Went for a short local drive and pretty soon (without me touching the stick) the red background on the D went out.
Played around a bit and Sport mode seemed to work as did the Tiptronic, so it was driving reasonably normally, though even in Tip mode there was no highlighting of the selected gear!
I think it was then sort of "stuck" in Sport mode, but not 100% sure, so drove home and parked the car and turned ignition off while in D.
Connected up VCDS, ignition on and had a peek - F125 code was 1111! (Plus of course codes stored about implausible signals)
Moved the shifter around and all other positions were normal (including P at 1000).
I note my earlier comment that "There can also, looking at the tracks, theoretically be a 1111 code between D and S" so I'm wondering what's going on inside.
I did then manoeuvre into my normal parking place which involves a fair bit of shuffling back and forth, during that it all went back to normal!
Old 8th March 2025, 08:40 PM
During my 14 years of D2 ownership I had mine replaced twice by my local trusted mechanic, not sure he found it all that difficult..then maybe I am lucky having someone very capable available, he kept my RS6 and Maserati going well for a number of years too and is currently doing a grand job of keeping the D4 running sweetly, his view is "they are just cars"
Old 8th March 2025, 09:31 PM
I recalled this post by MJ with some VERY useful tips: https://forum.a8parts.co.uk/showpost...&postcount=112
