Old 16th February 2011, 12:51 PM
You can find them easily enough - just feel in the gap between backrest and squab and you should have a pair of 4mm diameter pins between brackets, 1 on each side of the outer seats.
From experience of using them on my '02 S8 they can make modern child seats sit at rather an odd angle, particularly for rearward facing infant carriers. My son tends to loll forward in the seat when he's asleep in the S8, whereas in the A6 he stays head back. Access to the Isofix anchorages is also extremely tight and Maxicosi spreaders won't fit due to the side airbags.
Don't think I've got a pic of mine installed - will have a look
Old 5th March 2011, 03:33 PM
Scouse_Phil Scouse_Phil is offline
Does anyone know if this can be retrofitted onto a car without isofix?
I bought a isofix base when my little boy was born but now i have swapped cars to my a8 and its a pain in the a*se putting the seat in using the seat belts.
Old 5th March 2011, 04:02 PM
Phil
What year is your car?
Adrian
Old 5th March 2011, 04:07 PM
Tell me about it, I've been moving a baby seat back and forth from my '8 to an S4 back and forth this week and it's doing my head in as mine doesn't have ISOFIX because of the reclining rear seats. I suppose you'd get quicker at it after a while but have grazed knuckles from it.
I know people that have retrofitted it to an S4 in the past.
Old 5th March 2011, 05:29 PM
Just realised yours is a '99 from your intro post - that won't have the mounting points for Isofix as we were still drafting the standards for Isofix at that point
There's evidence that post 2002 build cars should have the necessary threaded holes (2 on each side) to allow a bracket with Isofix anchorages to be bolted in place, at least on A4/6, even if they weren't fitted as standard. Didn't investigate A8 at the time. Given that my S8 is a 2002 and does have them, it seems Audi did start fitting Isofix as standard on the A/S8 earlier than some of their other models, as you'd probably expect. A lot of A/S4, A/S6 don't have them from the factory and for months Audi swore blind to me you couldn't retrofit - then I came across a post online with part numbers from an Audi parts guy and sure enough Audi changed their tune.....
What seat have you got? We're using a Maxicosi Cabriofix which allows the base to stay in the car with adult seat belt holding it in. I do find the Isofix anchors are in a strange position in the 8 - they're a bit low compared to the seat squab so you end up with car seat leaning back a lot. Not a problem for forward facing, but for rear when my son falls asleep his head tends to fall forwards onto his chest, which doesn't happen in the A6.
Old 6th March 2011, 10:27 AM
Ive got this base http://www.mamasandpapas.com/product.../isofix_pv.php
I'll just have to put up with using the seat belt until hes bigger then the car seat can just stay in the car.
1999 - 4.2QS
Old 6th March 2011, 11:48 AM
At least you have the option to use the base with the adult belt, although a bit odd you still put the diagonal bit around the seat itself...
This is ours:
http://www.maxi-cosi.com/gb-en/carseats/baby/easyfix
I've been using our Cabriofix without the base as it's been in our A6 while my car's been off being painted and hadn't got around to swapping it back till today - it's a bit of a drag but it gets quicker with practice!
The Britax one is a real pain as they sell different bases for adult belt or Isofix restraint!
With the Group 1 seats for older children it's possible to get a really solid install with the adult belt - worth buying a seat protector to go under/behind it to stop the leather getting mullered - Babies R Us sells one that's proving pretty good.
Old 16th March 2011, 07:49 PM
Yeah, but you have the really cool facility to install the child seat, then wind the rear seat forward to take up the slack properly... Saves all that tugging at the seatbelt that 'normal' folks have to do...
Old 5th March 2011, 05:04 PM
Originally Posted by adrian e View Post
phil
what year is your car?
Adrian
1999
