If you have Brembos then there are no shims. Are these your brakes?
They may well be Teves, in which case all parts are replaceable.
Athough ive never used them, Big red come highly recommended from a lot of people. Including some nice polymer coatings, and a rage of colours (Inc black as factory).
'02 S8 - Ebony Black Pearl, 'Swing' Grey Leather/Alcantara, PDC, Xenon Plus, Bose, Phone Prep, Navigation Plus, TV, auto dipping interior and exterior mirrors, UV/Solar Tint Glass, Ski Hatch, Extended leather pack 1, Rear Sun Blinds, Memory Driver & Passenger Seat, Heated Front Screen, Heated Rear Seats. ![]() |
I had new disks and pads last month. Front nearside inside pad was dragging, overheating the disk, and has warped it. It was simply because of a small amount of muck and corrosion on the pistons barrels....which is perfactly normal if your last pads had been on a long time and run particularly low. The garage who fitted them (if it wasn't you...) should have checked that the pistons were retracting fully when they fitted them.
I am having a bit of a run in with Audi about this at the moment, trying to get them to fund another new disk because it is their fault that the first one warped. Zip |
Sounds like the slider plates have lifted due to corrosion behind them.
You can remove the plates by undoing the small bolts holding them in. T27 Torx if I remember correctly. Just make sure the bolt head is clean and the tool fits correctly as you don't want to strip the head on the bolt. Once off, the corrosion can be removed with a file. You'll need to reshape the plates in a vice afterwards. |
contacted Big Red, and they don't do the S8 Brembos.
Anyone found anyone else that will refurbish them? Zip |
No news here?
New Brembos cost the same as complete exhaust and adjustable suspension ![]() ![]()
2003 Daytona Grey RS6 2000 Silver S8 2005 A6 1.8TQ Premium 1993 Audi S4 2.2 TQ MTM 330 (my first love!) |
