just cycle through the ones for the engine as they may be different from my PF D2.
Temp readings seem normal on idle, couldn't test it running at higher speed (when it actually runs cold) because the laptop battery doesnt hold its charge and has to be connected to the mains constantly.
07 Silver D3 A/S8L Quattro ![]() ![]() |
If it runs OK standing and low speed but cold at high speed only thing that could be wrong is thermostat stuck open.
It has a new OEM thermostat and water pump fitted. Thermostat is working perfectly.
thermostat tested and working correctly
Then that only leave the pixies and a sender!
