Old 2nd April 2011, 03:51 PM
If it runs OK standing and low speed but cold at high speed only thing that could be wrong is thermostat stuck open.
Old 2nd April 2011, 04:59 PM
A8L Chick's Avatar
A8L Chick A8L Chick is offline
I guess you didnt read the whole post.
It has a new OEM thermostat and water pump fitted. Thermostat is working perfectly.
07 Silver D3 A/S8L Quattro S8 front end, Xenons, Bose, Bluetooth, Voice Control, Autodim mirrors, Heated folding mirrors, Double Glazed Windows, Electric Rear & Side Blinds, Black leather Comfort Seats with front memory seats & mirrors, Front & rear heated seats, Interior/Exterior light pack, TV.I.M, AMI, Parking sensors Front & Rear, Air suspension (soon to be lowered), Keyless entry & Start/Stop, 4 zone climate control, Power Boot Open/Close.
Old 2nd April 2011, 06:10 PM
Did the fitter test the thermostat in a bucket of hot water before he fitted it in time honoured fashion. New parts can go duff!
Old 2nd April 2011, 10:38 PM
A8L Chick's Avatar
thermostat tested and working correctly
Old 3rd April 2011, 05:42 AM
Then that only leave the pixies and a sender!
Old 3rd April 2011, 11:20 AM
A8L Chick's Avatar
Knowing my luck...it'll be the pixies
Old 19th May 2011, 07:46 AM
RanjS8 RanjS8 is offline
Default Engine running cold
Do these have a viscous fan cos that can sometimes cause the engine to run cold....the only other thing that ever caused an issue for me was a poorly sealed rocker cover on an old e36....but to be honest the only things that can normally cause it are thermostat or viscous fan
Old 8th December 2011, 06:41 PM
Hello folks! Did you get any further forward with this A8Chick?
I have the same problem.
My 2006 3.0TDI A8 is rather slow to warm up, and never seems to get to 90˚c in fact it seems happier at 60-70˚c.
I replaced the thermostat with a genuine one as I know these are known to stick open, no change.
Next I replaced the G62 coolant temp sensor to no avail.
The Webasto is working fine and I am manually turning it on, but still running cool.
The heaters in the car get warm but not hot like my old passat which suggests it really isn't getting warm, but could be a red herring.
Any tips? TIA.
Old 8th December 2011, 06:48 PM
is the fan on all the time or too much? temp sensor for the fan could be making it overcool the system??
Old 9th December 2011, 03:05 PM
I went for a run today was running very cool in this weather.
There is no viscous fan, but there are two well caged and shrouded electric fans and these are both running continuously (abet slowly) from startup, except with the climate control completely off.
VCDS shows that they are being told to run by duty cycle, and the Engine output tests speed them up and down correctly.
Group 7 also shows oil temp and this a few degrees higher as expected but still cold like the coolant.
It would appear that there is only one simplex (two pin grey) coolant temp sensor on this engine.
019 Fan activation\
1) Coolant temperature\
[\'b0C]\
2) Air conditioner fan activation\
3) Radiator fan 1 activation\
4) Radiator fan 2 activation\
