Yes, the D3 4.2 has a timing belt - although it shares more in common with the late B6 S4 engine than the D2 V8 it did have a belt whereas the S4 was the first to use a timing chain.
You should be changing every 80k or 5years. Full timing belt, tensioner kit and coolant pump with auxiliary belt is between £400-£500 Inc Vat etc. Dealers would be about £750 I think |
top man- thanks!
![]() 2001 Jeep Grand Cherokee 4.7 V8 2010 Buell Ulysses XB12XT- the final edition |
Learn something new every day. My 3.0 TDI D3 has timing chain, and the diesel pump is belt driven etc, I'm surprised all the D3's are not chains.
Ben-would you ever advise chaiging the chain? What would be your rough price for this?
07 Silver D3 A/S8L Quattro ![]() ![]() |
Tricky one this as cost of replacing chains is BIG. There's 4 or 5 chains on most of the late engines and they're loctaed at the back of the engine so it must come out. This make it expensive to do if there's no need. However, Ive seen a few 3.0TDi's break tensioners (especially driver's side bank at top) and they're starting to have issues with chains stretching, putting valve and fuel timing out! Thats petrols too though!
I will work out a quote for ya anyway just so you know! |
