gotta keep the inside of the car clean somehow
Audi S8 2015, Daytona Grey |
rofl!
ever get to the bottom of this? mine was rattling this morning on un even roads...
'02 S8 - Ebony Black Pearl, 'Swing' Grey Leather/Alcantara, PDC, Xenon Plus, Bose, Phone Prep, Navigation Plus, TV, auto dipping interior and exterior mirrors, UV/Solar Tint Glass, Ski Hatch, Extended leather pack 1, Rear Sun Blinds, Memory Driver & Passenger Seat, Heated Front Screen, Heated Rear Seats. ![]() |
No sorry, (one of my cats failed on Monday so had slightly more urgent issues this week
![]() ![]() cheers
mine seems worse when the weather is warmer must be some expansion/contraction thing going on I think
Did you check the sunroof seal and lubricate it? could be that it's drying out and sticking.
![]() However nothing obvious in there other than two metal strips that run from front to back around the middle of the sunroof which the headlining could be knocking against. Its def a head lining thing as I drove to work with it out today and ohh joy no knocking ![]() Going to try some foam stickers on the metal bits and see what happens, will keep you posted cheers
I know you can't do it now but if is it the actual sunroof knocking against the headlining? Mine knocks too and if i just push up slightly on the sun roof it stops. It's like the sunroof has some vertical movement in it. Dezzy's solution is to turn the wireless up a bit
What sunroof do you have fitted? I ask as that changes the head lining quite a bit, Ive got a glass 'moonroof' which has the slidey back thing, if you have a solar roof or an ally one I assume there is a peice of head lining attached to the inside of the roof.
