Old 28th April 2011, 06:16 AM
sloss's Avatar
sloss sloss is offline
I've played around in the tank when replacing a fuel pump.
That must be a tight squeeze!
My RR on Gas does not like starting on it from cold as the vaporiser just freezes - it need hot water through it first. Once everything is hot it's fine so you probably have no problem on the gas side.
Stew,
Old 28th April 2011, 06:19 AM
Stew,
Are you intimating I'm fat!
