Old 9th May 2011, 06:48 PM
Hiya
Understood it was a series of 2/3 digits on the manufacturers plate
Engine is a 40v (AVP) and gearbox is EUU according to info in service book.
Will the vag-com code be the ZF part number, or Audi only?
By the way I've got the ZF oil specs and filling procedure, if they're not already on here, from ZF last week. If you want them PM me your e-mail and I'll forward them
Old 9th May 2011, 07:23 PM
Hiya
You EUU box uses (I think) oil pick up filter 01V 325 429 B. This as far as I can tell equates to the ZF part number 211 27 02.
Usual disclaimer, I am an idiot and if you follow me it should only be out of morbid curiosity.
and PM sent
Old 9th May 2011, 07:33 PM
Although it's an EUU gearbox, there can still be differences, so you're safest with the serial number.
Old 9th May 2011, 08:30 PM
Hiya
After a bit of confusion over the transmission code I've sussed out that EUU is the final drive code. In that case your transmission code is either ECY or FBG. Therfore the part numbers are:
01L 300 041 S or SX if it's an exchange box
or
01L 300 042 P or PX
I'm betting it's ECY, in which case the information above is good.
Old 9th May 2011, 09:16 PM
That's great info judging by the 2 options mentioned, that must mean I've got a FBG gearbox as it's written right next to the EUU code in my service book!
What's the difference between the two that made you think the other was more likely?
Mine's a late car, so guess the sequentially later part number is likely?
Wonder if the ZF bloke will be able to use that number .....
Queue some late night Googling - this link looks useful:
http://www.audipages.com/Tech_Articl...udiProgram.pdf
It lists the comparable ZF part numbers for a given gearbox code or part number from Audi Interestingly it doesn't list the ECY/041S option
Old 9th May 2011, 09:36 PM
Yes, EUU sounds like a transmission code, used to identify the final drive ratio mainly, and FBG is the standard code for Facelift D2 S8's gearbox after about 2000/2001 onwards...
