i removed the lever from the valve and operated the valve by hand and it pushes the car up and brings it down slowly. i set it in the center and put all back and from then the rebound on the shocks seemed to be better, so the valve is working.i did see play on the linkages though.i wouldnt like to remove the system, i like the idea that i can load the car and it levels out and i dont mind fiddling till i get it right but not going to spend a fortune replacing parts.so as a last resort ill remove it. do you know how to bleed the system?or anyway to test the accumulators?
