Old 26th May 2011, 06:13 PM
Snaga Snaga is offline
so whats the difference between that and dynamic?
Old 26th May 2011, 09:29 PM
Dynamic is the new speak Audi use for Sport, as in Dynamic driving, rather than the obvious but perhaps lawyer scaring Sporty driving.
The Dynamic (Sport) setting int he air suspension his lower and firmer than the standard suspension.
Audi say that in a Sport suspension car the Comfort setting is equivalent to Dynamic in the standard cars.
I've only driven my D3, so have nothing to compare against, but I find the suspension surprisingly compliant.
You can tell when its in Dynamic (or Lift for that matter). Its not hard or in the least crashy, just a little tighter and a little noisier.
To check the type of suspension fitted. Switch on the ignition, press 'Car' button to right of shifter and the MMI screen will be headlined with Sport
Old 18th March 2013, 03:11 PM
Did we ever work out what the physical differences between 'sport' and 'standard' suspension were?
Is it just the ECU, or are the shocks different?
Old 20th March 2013, 07:47 AM
I dont know much about this but I believe that a fully bearing air suspension system is used. In conjunction with the CDC status-dependent electronic damping control, this ensures that the main - and partly conflicting - requirements are satisfied in an optimum manner within the limits of the laws of physics.......
But dont take it from me... I think that this self study programme will help here.
Old 20th March 2013, 08:12 AM
Looks like just the ECU then.. Hmmmmm
Old 20th March 2013, 04:22 PM
As you can see below struts are different as well
ID:	5771   Click image for larger version
Old 20th March 2013, 04:52 PM
So it's a whole different setup.. Ah well
