....or just drop it at QST for an hour and get them to do it
There are several ways of doing it. I normally do not take driveshaft off, just pull it out of wheel hub then CV joint off. And to do that I disconnect lower suspension arms at the wheel hub not at the subframe.
The 6 bolts at output flange should be replaced or at least threadlock used when putting back as I have seen them get loose/come out on several occasions if old ones are reused without threadlock. Therefor I do not get them out if I do not have to. |
Hi Guys,
just to echo Ainarssems feelings about dropping hub bolts rather than the sub frame end, I would suggest this is good practice, and, if hub extraction was ever the intention, it makes for a less cumbersome unit once at liberty!! Best Regards, Steve |
