Old 4th June 2011, 03:22 PM
A8L Chick's Avatar
A8L Chick A8L Chick is offline
Originally Posted by cathedral60 View Post
Thats what always happens. The pump filter over time gets clogged with algae type substance, due to screenwash and stuff. Thats why using the calgon tablet thingy works to help reduce this build up, reducing the need to remove the wheel arches etc.
You have to watch sometime when cleaning the washer system, cause believe it or not the washer system can harbor legionnaires disease
Glad you got sorted though its a bugger when they dont work
Indeed, most washer systems carry that disease, I have to be particularly careful in my job.
The calgon tab didn't help at all-in fact it made mine worse lol. But it was only a 10 min job which even the simplest of people can master so I thought I'd share with those who have the same trouble
Bex
07 Silver D3 A/S8L Quattro S8 front end, Xenons, Bose, Bluetooth, Voice Control, Autodim mirrors, Heated folding mirrors, Double Glazed Windows, Electric Rear & Side Blinds, Black leather Comfort Seats with front memory seats & mirrors, Front & rear heated seats, Interior/Exterior light pack, TV.I.M, AMI, Parking sensors Front & Rear, Air suspension (soon to be lowered), Keyless entry & Start/Stop, 4 zone climate control, Power Boot Open/Close.
Old 9th November 2014, 05:10 PM
Tuizner Tuizner is offline
Smile
Just did mine today on a D3. I had the same issue with blocked washer jets. For info the headlight jets were fine. This is because those pumps are higher than the windscreen jets on the washer bottle.
Anyway the filter was clogged with white gunk - a quick clean and all is as new - washer working perfectly. I will try to upload some photos - it is a fairly easy job when the wheel is removed. Did mine at the same time as changing to winter tyres so even less of a faff.
Here is the job:
You need to pull the top of the felt wheel liner away:
Then you can see the two pump assemblies :
The bottom pump is for the screen jets. You just pull/lever the pump upwards (can disconnect the electrics or not - I did just so I didnt break them but there should be enough wiggle to leave them be). The pump comes away and leaves behind a rubber grommet under which the filter is attached. Mine was full of snot / white / clear algae.
A quick clean:
Then all back together in reverse and jets are now back to being jet powered !
Old 9th February 2015, 02:00 AM
johnny_quattro's Avatar
Default Calgon liquid works perfectly on a D2 A8L
Symptoms for me: no washer fluid being dispensed in the direction of my headlights although I could hear the headlight washer jet pump operating.
Emptied the reservoir first by repeatedly operating the wipers with the headlights on, of course. Refilled with approximately half a bottle of Calgon liquid (300ml-400ml), and about 1 litre of water as the liquid was quite thick and just glooped into the filler hole.
It didn't work at first or for the next couple of days for that matter. Tried it later in the week and lo and behold, my washer jets for the headlights were now working. I'm sooooo pleased with this quick fix as I didn't really fancy having to investigate further.
Old 23rd October 2016, 08:07 PM
woodie227 woodie227 is offline
Whilst an old thread, I found this very useful and relevant to my '08 3.0 Tdi D3 Quattro at 71,000 miles.
Symptoms: Feeble windscreen wahers but working. Headlamp washers appeared ok.
Cure:Taking the more 'difficult' route of part- removing the wheelarch liner to get at the small filters in BOTH the rubber grommets of both pumps, windscreen and headlamps.
The only amendment I would make to previous posts is that it is essential to clean the higher pump (in the washer tank) filter as well as the lower one.
Mine was even more clogged with algae than the lower (windscreen) pump filter.
Good practice having to remove the liners too, as there's bound to be a reason for doing so at some time in the future!
Thanks for very helpful posts everyone.
Newly purchased A8 Sport 3.0TDi (May 2008) D3 with ASB engine 71,000 miles. NO DPF!
