Old 12th March 2009, 03:45 PM
Added to Sticky
Old 12th March 2009, 04:00 PM
Boy Conan you sure are the quickest Librarian in the west!!
Old 13th March 2009, 11:34 AM
DJStrange
Guest
Posts: n/a
Updated with a diagram - should make it clearer I hope
Old 13th March 2009, 11:54 AM
Ska's Avatar
Ska Ska is offline
Woops! & I got a bit of a judder the other day
Thanks for the info DJ though I think mine are slightly different to yours; I run the 4 pad Floating caliper arrangment up front.
Old 13th March 2009, 01:16 PM
harpersimon
Guest
Posts: n/a
Ska I have these same symptoms. It used to judder a while back.. but then went away. Just recently its back, pretty well noticeable all the time at about 65-70, then will go away.. come back..first of all felt like wheel balance, but I recently had them all balanced when changing the wheels over so not that - definitely notably worse under braking, to the point where when the car is coming to a stop and I have my foot on the brake pedal, I can almost 'feel' the pads grabbing a bit.
Warped discs I am thinking.. hence the other question about which discs to get (I think I have the same setup as you so will be looking at 345mm - any rough price I should be paying)
Anyway will watch out for all this although dont' think my calipers have been painted at all. I'll make sure the surfaces are properly clean though when I get to changing the discs.
Old 16th March 2009, 12:28 PM
DJStrange
Guest
Posts: n/a
I got my discs from GSF down Greenford, I think they were about £120 the pair (345mm) - I haven't got the receipt handy. I had to pay another £12 on top of the price of the 323mm ones anyway, if that gives you a clue.
Incidentally, who was it in the A8 4.2Q "N117 ***" friday last week? Silver it was and looked nice and clean, somewhere near Southall I think it was. I was in a works truck so you wouldn't have noticed me.
Just as a sub-note, when mine were juddering, it wasn't like the pads were contaminated - you know, like a lack of friction judder. This was physical contact/no contact juddering, like the discs were warped big time, it felt a bit like the car was struggling to do the ABS thing as though I was on ice, but I know it wasn't an ABS fault as the light didn't come on and the juddering carried on after I released the pedal, then gradually faded as the discs obviously got cooler. Also, the outer wear band had a hint of blue (over heating) and the pads stunk like worn clutch.
The discs now look like they should, smooth even wear right across the landing zone. They bite really well now too. Shame the gearbox is kaput again...
Old 16th March 2009, 01:47 PM
Ska's Avatar
Ska Ska is offline
No it wasn't me. Though I make regular trips to Southall for groceries I hardly take the 8 there for fear of mindless delivery drivers in that area.
Now I'm thinking you used the Hayes by pass to get there? If you did you proly drove passed my house with the 8 parked in my drive.
