Old 18th June 2011, 10:40 AM
A further update to this - ZF now have a rather useful online catalogue similar to VAGcat called WEBcat - if you use the link below -
ZF WEBcat
Then you can select Audi and the D2 A8 and your model and it will give you the correct gearbox spec for your particular car -
mine is actually a 5 HP 19 FLA and then it gives the Audi Code also which is 01V 300 043K on mine. I have checked the label that I took a pic of on my new VAG gearbox when it arrived and this is spot on. might be a useful one for the gearbox sticky Mike?
Old 18th June 2011, 01:14 PM
Good find Neil, added to sticky.
