The fan you can hear ide say is on very slow. Steve asked, does anyone have a exploded view, of how to take this area apart. As he knows nothing about this car, or his way around this car. We take it, a build up of rain water, stuck in scuttle has caused this over time, As tueday we had water coming out the back vents.
![]() Last edited by A8 Owner; 24th June 2011 at 08:38 AM. |
![]() ![]() ![]() Right looked where you said Ian, Pulled the 40a fuse on left just under the relay that has 204 on it. Fan now stopped ![]() ![]() Took pics, Can someone now tell me what this fuse does and where it goes. or possible causes of fan been on. Not taking for granted that the relay above it is connected to same thing. Rang Steve he said without looking, if relay above is connected to the fuse we should first change this. Anything else it could be as i want ro ring A8 parts to get things sent. Thanks for the Help so far
![]() Last edited by A8 Owner; 24th June 2011 at 09:17 AM. |
Thanks Mike think thats what he wants. Can i be a pain and ask if u can copy and paste what the number key is.
i.e what the numbers are. As for me the only thing electrical i can see other than fan is number 16 ![]()
The legend is not so easy Mel, but you can go to the website and if you register for free you can see them side by side.
www.Vagcat.com
He has been to Audi, got new relay. Fan still on tho, if fuse connected ![]() ECU box is dry inside as Steve checked that also, as its in scuttle. Just lucky no need for heater at mo, so theres a up side to it ![]()
Please see the attached pdf's. Had to split in 2 as in one file it is 196.3k and max allowed here is 195k for pdf's. If it does not work drop me PM with Your e-mail and I will send it to You.
Mike You can get anything that's on the screen by pressing "print screen" button, then paste into paint and save picture. Or get CutePDF program(free) like me. That's a virtual printer which saves anything You can print to pdf files. Together with iCopy(also free) You can also scan straight to pdf. |
