Old 12th March 2009, 11:44 AM
harpersimon
Guest
Posts: n/a
Default Brake Discs
Am about to (or need to basically) change the discs on the front.
When enquiring with the local parts place, unsurprisingly I got 'which ones sir.. these ones are more expensive than those ones.. blah blah blah...'
essentially I want to replace the standard discs and not spend more than I need to a this point in time - commuter car, just need it to stop shaking my hands when I press the brakes!
So is it really a case of me taking a wheel off and measuring across the disc to get the right ones, or is there some other way I can tell - code? something like that?
Old 12th March 2009, 12:23 PM
All pre facelift non-s8's front discs should be the same - 314 x 30mm
It is in one of the codes on your build sticker, which will then translate to a part on ETKA....
Old 12th March 2009, 01:41 PM
Ive got the same problem HarperSimon, mine is in to have new discs and pads all round in the next couple of weeks (kerchingggg!)
Ive got a feeling its due its major service soon as well (Kerchinggg!)
Ah well, it will still make me smile . . .
Old 13th March 2009, 01:21 PM
harpersimon
Guest
Posts: n/a
Thanks mate - the guy defo told me there are 2 diams though - same as Ska says in the other post - 323 or 345mm
Tell you what, I'll stop being lazy and measure the disc (when my new locking wheel bolts arrive as the current one got destroyed by the tyre place!)
Old 15th March 2009, 01:40 PM
Those sizes sound facelift, as they are bigger... 323 is the standard facelift front disc.
The only variation in discs for prefacelift is for the S8 (which are slightly larger), otherwise, every engine has the same front and rear setup....
Old 17th March 2009, 04:30 PM
harpersimon
Guest
Posts: n/a
quick ruler across and they are 314. Like should have questioned the Oracle..
Old 17th March 2009, 07:32 PM
haha hes staring at you over his glasses as you speak
Old 18th March 2009, 12:06 PM
harpersimon
Guest
Posts: n/a
yeah yeah i will crawl back under the car..and stick to things I know about..
now.. er.. what do I know about exactly.. er..
Old 14th May 2009, 03:26 AM
AUDIA8MAN
Guest
Posts: n/a
zimmerman have replacement discs and they are very good and cheap!!!
