Old 4th July 2011, 12:52 PM
On the front it's quite easy if you have the springs mounted on the struts already. You can remove the 2 lock nuts that hold the strut into the top control arm carrier from inside the engione bay. Undo the nut and slide out the bolt from the lower control arm and you can jiggle the strut out and replace.
The after end can be a bit harder and a lot of typing so give me a call and I'll talk you through it. Did Chrisp17283 this morning and his whole front end on Saturday. Before anyone else says anything, yes we did get the rear lower control arms on the wrong way round!!!!!
