Agree with Mike; the paint on these beasts are tough IIRC Mike uses Menzerna Power Gloss for paint correction and defect removal as do I. This product has a high cutting ability and it still takes quite a new of passes with a rotary polisher to get rid of swirls!
Failing that you could always wet sand if there were not many defects.
Mine will just be washed well I'm afraid.!
Spending all day detailing then driving to work down the M6 in the p*ssing rain and roadworks would just depress me too much! |
I'll put some pics up later and you'll see what I mean. Bill
"Man Math" - The means by which a caring husband convinces his wife that a 4.2 A8 is in fact cheaper to run than a tiny Auto crap box "Being in touch with your feminine side" - The ability to, in the 30 seconds following a major accident, obtain your wifes approval for replacing your big german car with another "because otherwise we'd be dead". See also sulking for two years until she finally allows you to get another purely on the basis of your current one being the wrong colour. |
I made a tentative attempt on the boot area of my S8 using Meg's SwirlX last weekend with a rotary (not a G220) and wasn't too impressed. I used Meg's products to wash the car, then kept the speed relatively low on the rotary and went over the same area 3 times with SwirlX. It didn't do much. Does anybody know if SwirlX is a weak cutting compound? I did get a good shine using Meguiars NXT polish and carnuba wax though, but those swirls are still there! Last edited by jmw748; 17th March 2009 at 10:55 PM. |
SwirlX is a non abrasive polish. On VAG paint you could polish with an industrial floor polisher and have little effect. If the swirls are that bad you should try a medium to heavy cut compound polish. I recommend Poorboys SSR 2.5 as th medium cut and Menzerna Power gloss as harsher cut. Use the SSR 2.5 first. If neither of those do it after a couple of passes try Megs #85 polish gingerly, be carful (especially with a rotory) with it as it's quite abrasive and will need you to follow up with something like poorboys SSR 1 to remove any hazing or buffer trails.
