Old 9th July 2011, 10:44 AM
I don't think the fuel filter is in the Audi service schedule but get it done anyway, the pollen filters are certainly DIY, it will take you two minutes even with no mechanical ability to change them. Lift up the bonnet and look directly in front of you, you can't miss them. Consider doing the brake fluid and if you have time, maybe even the power steering flush too, there is a good 'how to' for that on Audipages. I used spark plugs directly from my Audi dealer, however others use ones from local motor factors. NGK are good.
