Old 18th July 2011, 01:48 PM
Curtis's Avatar
Curtis Curtis is offline
thanks
so can put HID on the two projection lights and leave the normal lens bulb for high beam and if they are adjusted correctly the law wont know any differant.
if i wanted to put fog lamps in the bottom grill of the bumper i need to replace the bumper with a fl bumper will i need to change the headlights to fl or can i keep the pf headlights?
im just trying to think ahead before i decide to do one thing and later on it causes more work.
Old 18th July 2011, 02:12 PM
A facelift bunper will bolt straight up but will leave a gap under the bonnet grill that extends about an inch either side under the lights.
Old 18th July 2011, 02:51 PM
Otherwise known as "an additional air intake!!"
Old 19th July 2011, 06:06 AM
Curtis's Avatar
lol. so will need a new bonnet aswel. think thats a bit much.is there anway i can fit fog fog lamps in the lower grill without causing more problems or air intakes. is it possible to change just the lower black part of the bumper?
Old 19th July 2011, 06:33 AM
PF was a single piece bumper so no ability to swap. To get lower grill fog lights swapping to FL bumper is easyist way and live with the gap.
Old 19th July 2011, 06:49 AM
Curtis's Avatar
is it a bad looking gap or will you only notice if you have a good look at it?
Old 19th July 2011, 05:51 PM
Anyone got a pic of the gap showing the FL bumper on a PF car?
Old 19th July 2011, 07:28 PM
Here you go...............
Old 19th July 2011, 08:42 PM
lol thanks Mike - the Projekt car lives!! it doesnt show as much when its all black
someone should look to making an aftermarket "infill piece" im sure they would sell a few, perhaps coloured the same as the bumper, or chrome
also you need one of these mike for that car -
Old 20th July 2011, 03:02 PM
Default yes I do
Yes I do!
Tags
fit
