Old 28th July 2011, 11:01 AM
barzya8 barzya8 is offline
Default Vagcom register
Hi Guys and Girls,
Being fairly new to the forum, could someone explain how this register works.
My recently purchased A8 is in need of some diagnostic treatment. Went to a local Audi Specalist in Guildford, who wants to chage me £58 + VAT per hour for this service.
As I am based in Guildford, Surrey the closest guys to me are Notorious in Reading, Architex_mA8tey in Swindon and mkoneman in Oxford.
Do you contact these members direct and make an appointment. If so what would the charge be, if any (hopeful)
Also I would not know how to operate this equipment or read the codes it threw up, so would need someone to help and show/explain.
I am happy to pay for this resource/service, but would like to think I could get it cheaper through the forum.
Finally, does anyone know of a good Audi Specalist in the Guildford Area.
Old 28th July 2011, 08:18 PM
Hi Barzy
Depends how quick you need it I guess, most of us will happily run a scan for you and try to help. I can let you know if im passing on the M25 on my travels soon and I will leave the others to answer themselves. I dont charge nor do most guys but I guess most of us wouldnt say no to the odd donation towards the cost of their leads, or pint
MkOneMan has a business called OBD works now which will give a fuller service if you'd like that -
www.facebook.com/obdworks
full genuine ross-tech vcds
full genuine vag- tacho
An alternative is to come to one of our meets check out the meets thread HERE for the next date and come along with us, and I'm sure we can all take a look at your car and see if we can sort a scan etc
Old 28th July 2011, 10:56 PM
Thanks Architex_mA8tey for your prompt reply.
I currently spend quite a bit of time out of the UK so unfortunately will not be able to make any of the meets listed.
Thanks for the FB link to MkOneMan at obdworks in Oxford.
I will be back in the UK for two weeks from the 23rd Aug. Would be happy to come to you at your convienience, either during an evening or at a weekend, whatever suits. Happy to make a contibution to leads and or beer tokens.
Thanks
Barzy
Old 29th July 2011, 06:54 AM
Hi Barzya
I'm in Southeast Kent in case thats any closer to you. I work in central London and could easily meet you somewhere in town after work.
Goran
Old 7th April 2012, 11:41 PM
dragondownsouth dragondownsouth is offline
Clive, Leeds, Hex+Can USB Genuine Ross-Tech
Mike, Plymouth, Hex+Can USB Genuine Ross-Tec
Jon, North Yorkshire - Numerous Diagnostic Equipment
shark_90, Midlands, Hex-CAN USB, VAG Commander + others
Singh - Warwickshire, Genuine Ross Tech Version
mkoneman-oxford-every ross tech lead '94<
PsYcHe - Glasgow(ish) - Hex-CAN USB (proper Ross-Tech)
Entwisi - East Lancashire - Key-COM serial version genuine ross tech
Ska - (middlesex no longer exists so West London) Key-COM serial version genuine ross tech
darren bradford, west yorkshire-hex+can usb genuine ross-tech
Dezzy, Bideford, Devon. Key-Com serial Genuine Ross-Tech
Steve - Merseyside. Hex+Can USB Genuine Ross-Tech
Ali-Luton- genuine Rosstech serial version with Full licence
Architex_mA8tey - Swindon - Hex+Can USB Genuine Ross-Tech
Richard - Pembrokeshire - Genuine Ross Tech (Key-USB)
Sloss- Aberdoom - genuine Ross Tech Hex+Can USB from Gendan
Limoncello - Leeds - genuine Ross Tech Hex+Can USB from ilexa
Hibberd-Assen Holland. - genuine Ross Tech Hex+Can USB
Godders, Wrexham nr Chester - genuine Ross Tech Hex+Can USB
Titan - Glasgow - Hex-CAN USB
Daviesbike-Abyrystwyth north wales-Vag com-Ross Tech VCDS light +can, Gendan usb
Notorious - Reading, Berks - VagCom VCDS USB
dragondownsouth - Wellingborough - Northants - genuine ross tech usb + can
Old 8th April 2012, 08:10 AM
I used to live in Wellingborough, moved to Rushden last year.
Old 8th April 2012, 08:15 AM
ainarssems-Rushden-Northants- £8 e-bay lead with VAGCOM, VCDS, VWTool + ELM327 Bluetooth with Torque on Android +Galletto 1260. Would like to try VAS 5054A
Old 8th April 2012, 08:33 AM
HPsauce - South Bucks - Registered VagCom (upgraded to registered VCDS-Lite) with eBay USB lead.
Old 8th April 2012, 08:47 AM
47p2's Avatar
47p2 47p2 is offline
47p2-Glasgow, South Side-Genuine Ross-Tech Hex-CAN USB
Nite Blue 3.0L SE Quattro
Old 22nd August 2012, 12:18 PM
Exerqtor Exerqtor is offline
Mike, Ashburton, Hex+Can USB Genuine Ross-Tec
Exerqtor - Norway, Halden - Genuine Ross-Tech Hex-CAN USB
