Old 2nd August 2011, 11:57 AM
del944 del944 is offline
I've had a similar sounding problem with my wipers, which went very slowly before stopping completely in the middle of the screen.
Further use resulted in a 10 degree sweep of the windscreen, with the wipers still stuck in the middle.
I pulled the wiper assembly out and the drivers side spindle is seized almost solid and would only move after the careful application of a lump hammer!
I couldn't actually get the spindle out so have thrown the whole lot back in again and will get a new linkage assembly, around £198 from Audi...
By the way, anyone know how to remove the electrical connector from the wiper motor - mine wouldn't budge..!!
Old 4th August 2011, 08:04 PM
FireStorm FireStorm is offline
Bolts often work there way loose
Tags
battery, electrics, fault, problem, wipers
