I just compared mine side by side, one is definitely shorter by a few cm.
I only bought half-shafts as the full shafts are too expensive from Audi, and even the half shafts were £211 each before vat! Anyway, I'm sure the German chap made a mistake, they must be different lengths otherwise his car wouldnt have worked ![]() My part numbers for half shafts are: 4D0407418 4D0407417 just checked on VagCat for a 1998 5 or 6 speed manual, part numbers are the same, so you should be ok with ones you bought: 1B 4D0407417 drive shaft with constant velocity joint inner left / 5-speed man. gearbox: AAH,AEJ,AEW, ACK 6-speed man. gearbox AHC (1B) 4D0407418 drive shaft with constant velocity joint inner right / 5-speed man. gearbox: AAH,AEJ,AEW, ACK 6-speed man. gearbox AHC |
