H Nollywood, just measure the 01E prop shaft so you can get a rough idea if its longer or shorter than the Auto box prop shaft.
I measured from the point in the picture to the same structure at the other end. Length between these points roughly: 170.5cm Magnets stick to the shaft tube, so it must be some type of steel. If you need any other measurements let me know. |
