I have a spare Gendan cable that'll work with the free downloaded software, i no longer use as i have a genuine cable now. You'll be quite limited to what can be done with it tho.
Is that a CAN-BUS cable Dezzy? If not, then it's almost useless in a D3
No
Is VCDS-Lite working with CAN-BUS anyway even if you have CAN interface cable? I though for CAN you needed full software.
Erm... Not sure.. could be right.. and if it's the ross-tech cable, then you can run the full version anyway so it beomes a moot point I suppose.
You may need the full version for the proper diagnostics of MMI
Right: new problem. AUDI upgrade discs refuse to be read by my CD player. I'm guessing that because I have an early D3 that either the CD player is too old to read them or the MMI is supersonically old.
Any advice? ![]()
2003 A8 D3 3.7 "Jean-Luc" 1989 190 "Colditz" 2007 Fireblade "The Blade" (Stolen October 2011 ![]() |
Depends which discs. The 5570 set should work with just about anything. But if you can get hold of the 2120 (I think it is) that should update an old version.
