Old 14th September 2011, 09:25 PM
Before you start its a good idea to plug your battery into a charger.
During the upgrade process you are warned no to switch anything on or off, and your battery may well give up before the upgrade completes.
Tell us about your new motor. And pictures, the more the better
Old 14th September 2011, 09:32 PM
I'd not bother with the battery meter, it doesn't work anyway
But yes you need VCDS for those.
Old 15th September 2011, 08:02 AM
A8 Doc A8 Doc is offline
A charger should hold the voltage enough though. If in doubt plug in VCDS and monitor the voltage on the engine module.
Old 16th September 2011, 06:33 AM
Big Blue Big Blue is offline
Run the engine during the process and turn off everything else.
Surely the reason the Audi dealership notes advise a battery charger is because they are in a workshop and the service manager would rather pay 50p for running the charger than £3 for using client's petrol?
2003 A8 D3 3.7 "Jean-Luc"
1989 190 "Colditz"
2007 Fireblade "The Blade" (Stolen October 2011 )
Old 16th September 2011, 11:24 PM
But when after an hour or so you need to pee. Leaving your car sitting there on the drive with the motor running....
Old 22nd September 2011, 02:44 PM
I'm assuming my prostate is up to the job.
1989 190 "Colditz"
Old 23rd September 2011, 08:57 AM
its the boredom that gets you and resisting the urge to put the tv on
