TozoM8 has been very helpful, he made a custom clutch pedal himself from steel. I dont think there is a stock steel LHD clutch pedal. I'm going to go ahead an use the LHD brake pedal and modify it to connect to the clutch master cylinder either with the brake booster clevis, or by welding the steel bolt from the aluminium clutch pedal onto the LHD brake pedal and mount the master cylinder to the right side of the cluch pedal.
The LHD brake pedal is alredy usefully curved off towards the brake pedal with just the right separation.
