Old 22nd September 2011, 09:44 AM
ukinvestigation's Avatar
ukinvestigation ukinvestigation is offline
i have a "square" RNS-C unit , will an RNS-E unit still fit ? ..... ive seen a bosch nissan connect unit thats identicle to an RNS-C is size and looks, would one of those fit ?
Old 30th November 2011, 09:53 AM
Thumbs up a8/s8
i was the unlucky/lucky man that bought your old project can you tell me a few things first cant get phone to connect to rnse cant get them to pair .im i doing something wrong? the car comes up with airbag fault the privios onwer said problem with front seats ? what is the switch next to the lpg gauge in the door panel? and what is the circle cover down at the drivers side piller i tried to contact the last owner but refuses to talk thanks
Old 2nd December 2011, 12:23 AM
RanjS8 RanjS8 is offline
Default airbag fault
My brother in law had this car before.....the interior is absolutely awesome...full of gadgets....
In terms of the airbag light....get the car on vag com...and you ll immediately know where the fault is....then either get the offending part changed or bypass it using a resistor....
The other bits I m not sure on sorry....in terms of bluetooth...do you have other phones you could try....my brother in law had an iphone...seem to work fine....but i know from experience that my nokia would never pair up properly with a bmw i had before....so worth trying a different make of phone first....
Old 2nd December 2011, 08:24 AM
If you need some VAGCOM help, I pass Broxburn fairly regularly, or you could take a quick drive to Blantyre and I could scan it for you.
Old 2nd December 2011, 10:21 AM
Car was fine when I sold it, no airbag lights and phone connected every time. I can't remember how to connect it now, it took me about 10 secs when I collected the car though so isn't hard. Adrian E should be along soon, he knows how to do it.
Old 2nd December 2011, 11:48 AM
Ah well, since you asked
Press the phone button on the rns-e
Make sure Bluetooth is on on your phone and it's set to discoverable if needed
Press setup on rns-e (must be set to phone 1st!)
Set a Bluetooth pin which can be whatever you want eg 1111, then your phone should pick up a device with Audi in the name
That should be job done
Old 3rd December 2011, 09:12 AM
christhompson's Avatar
Mine came with an OBD II scan tool. Invaluable for re-setting airbag light, abs light and others. Not expensive. This site is USA but I'm sure you can get one nearer. http://www.diydiagnostics.com/ Worth every penny
Old 20th December 2011, 02:01 PM
Hi and welcome to the forum. We normaly like pics but in this case you don't need to as the 8 you have is known well.
But if you take a picture of what you're looking at i'm sure we could help or at least Amar anyway.
If you plug it in to vag com it'll soon tell you if it is the seat air bag. There is a uk company called gendan see http://www.gendan.co.uk/product_VAGUSB.html can have you plugged in for 20 notes
Old 28th December 2011, 06:51 PM
Default a8/s8
sorry i thought no one replay me still trying to find out were to post qustions etc.got phone working thanks
Old 28th December 2011, 06:53 PM
Default broxburn
thats great if you are passing lets us now or i can come to you in the new year thanks
