Old 22nd September 2011, 02:44 PM
Big Blue Big Blue is offline
I'm assuming my prostate is up to the job.
2003 A8 D3 3.7 "Jean-Luc"
1989 190 "Colditz"
2007 Fireblade "The Blade" (Stolen October 2011 )
Old 23rd September 2011, 08:57 AM
its the boredom that gets you and resisting the urge to put the tv on
Old 26th September 2011, 09:32 AM
Scotty1 Scotty1 is offline
Default Well...didn't go that well...trip to Audi planned
Well I took the advice above and went for 5570.
Plugged in the charger,
Removed and CD's
Made sure my phone (BT) was miles away etc.
Disk one went well and as expected.
Disk two went well and as expected I had to do it twice.
Disk three went well.
Happy me...no...seems the jump from 900 to 5570 is too great and now the BOSE is in Component Protected (CP) mode, so I only get sound through front left speaker.
I have the Ross-Tech cable etc but as those in the know will tell you, this won't fix devices in CP mode.
So trip to Audi planned for Wednesday.
Old 26th September 2011, 09:56 AM
Clear all fault codes, and re-run the disks. Mine did that and a second run of the disks seemed to sort it out.
Old 26th September 2011, 01:57 PM
Tried that last night.
Cleared the faults but it doesn't clear the 'CP'. Once you re-insert the disks, they just report that everything is up to date and you can't up date anything.
Old 26th September 2011, 02:11 PM
nothing will clear the CP, Audi dealer must do it, only takes 15 minutes or so.
Old 28th September 2011, 07:47 AM
A8 Doc A8 Doc is offline
Ideally you need to jump to around 1000-2000 series software. It will then go into CP. Then run the final 5570 and sometimes it pulls it out of it.
Old 28th September 2011, 10:13 AM
I don't understand why it's designed like this, seems like a crap design to me. I understand the need for CP from an anti-theft perspective but most computer upgrades are cumulative or have a basic check to ensure that the upgrade is appropriate.
Audi engineers must also fall foul of this problem when having to perform updates and as such it would be better to design them properly. I’ve worked in the IT industry for over 20yrs and worked on everything from Mainframes, Mid-range, Unix…and this would never happen. Especially when blowing proms as this is doing. I think the automotive industry has a bit of catching up to do.
I have my visit to Audi today and hope to get the CP fixed quickly.
Old 29th September 2011, 10:03 AM
And...20mins later the CP is cleared and all is good with the world.
So on reflection:
Jumping from 900 - 5570 shouldn't be done in one go. While it didn't 'break' anything, it does cause some issues.
Look and don't accept what people on the forums say as 'fact'.
Most of the feedback is from people 'trying' these things at home. Based on what I have read and done...each upgrade can go differently. My experience shows that you can't upgrade but I've needed to go to Audi to get CP removed. No harm done and in the end I've saved a few hundred pounds not having an Audi engineer sit and watch the screen for a few hours. If you have concerns...spend the few hundred pounds and let them do it.
Thanks to those who helped.
