Old 2nd October 2011, 08:02 PM
That's a D3.. So it's a facelift bumper too. I think that grill is a full assembly from memory, but maybe someone with a newer ETKA can check.
Old 2nd October 2011, 09:55 PM
Should be seperate according to ETKA and cost about £75.00 to £100.00
see the screenshots below -
Name:	front number plate D3 - 1.jpg
ID:	2362   Click image for larger version
Name:	front number plate D3 - 2.jpg
Old 3rd October 2011, 06:06 AM
Markr Markr is offline
Thanks both - number 38 is the offending item - not sure I can justify £75 to £100 for replacement though - looks to be about £4 in plastic - so should be about £20 when you add a couple of 100% markup's.
I might have a go at removing from the car, and take some wet and dry to it followed by my DA polisher to see what happens.
Mark.
Old 3rd October 2011, 08:51 AM
Paints4u do an awesome little scratch repair kit for around 15 notes that contains everything you'll need.
Old 4th October 2011, 08:55 PM
Sorry for delay in responding - been to Guernsey for a couple of days.
Anyway, I have something very similar to the paints4u kit from Mer (called the Mer scratch Repair kit), which is essentially a rebadged Farecla kit, which I have used in stone chips previously - can highly recommend it, but watching the video is a must, otherwise the thought of using wet and dry on your lovely paint is horrific!
I am going to try and find another piece of similar self coloured plastic to have a play with - I am confident that I can get the scratches out with the 2000-3000 grit paper, but never tried using the compound to bring plastic back to a gloss finish
Thanks
Old 5th October 2011, 08:01 AM
I'm using the paints4u kit for somechip damage on the bonnet wings and a few scrapes and knocks around the car. I'm not after a A1 finish as my 8 isn't the best anyway. I've been using 2000 wet dry paper and it looks horriffic but a good compound polish and all is well.
The paint match from the paints4u kit is very good and even with a unseasoned dummy like me doing it it's hard to spot where i've repaired.
My car will be at ADI and i'm more than happy to let people have a play with it, the kit will be in the boot and i doubt i'll get round to polishing it now before the wk-end.
Old 5th October 2011, 11:39 AM
Well I got paint from paints4U for a Freelander and colour was noticably different
