Glow plug light is flashing, points towards injection system issues. Engine light backs it up too you see
![]() Injectors chances are it will be 1 or two. And you can pick them up for around £150-180 new, or used full sets for £150. http://www.ebay.co.uk/itm/NEW-GENUIN...item3f108ede2b http://www.ebay.co.uk/itm/ASB-BKS-BM...item336e92b497 Easy job!!! |
Although it's early days as your car hasnt been diagnosed, it it is the injectors, try and get the latest letter-suffix you can find (taking into account the price), as the early ones are crap by all accounts.
Certainly don't get earlier versions than you already have. Here are two interesting threads if it turns out to be injectors.... http://www.pistonheads.com/Gassing/t...&t=991409&nmt= http://www.audi-sport.net/vb/a6-s6-a...ce-please.html Last edited by snapdragon; 5th December 2011 at 08:13 AM. |
OK, I have the scan and these are the 3 fault codes the car has come up with:
004195 - Fuel Pressure Regulation P1063 - 006 - Control Range Not Reached - MIL ON Fault Status 00100010 004195 - Fuel Pressure Regulation P1063 - 002 - Control Range Not Reached - Intermittant Fault Status 00100010 006256 - Transmission Mount Valve 1 (N262) P1870 - 001 - Open Circuit Fault Status 01100001 HELP!!!!! I really do want to just cry now ![]()
07 Silver D3 A/S8L Quattro ![]() ![]() |
I can't remember if the 3.0TDi has a single fuel pump, or a dual stage one. It still could be a leaking injector, which would prevent the rail pressure building. Do you have VCDS yet? |
Still no VCDS for the foreseeable future ![]()
![]() Fuel pump or injectors based on above..... |
![]() Thanks for all input. Will let you know how all the tests go ![]() EDIT - She's booked in for the 15th ![]()
07 Silver D3 A/S8L Quattro ![]() ![]() Last edited by A8L Chick; 6th December 2011 at 11:32 AM. |
Should of brought a V10.......!
