Thats exactly what I'm seeing.
Thanks for checking. I'll relax a bit now. |
Sorry, misunderstood at first, I thought you meant it was in the main display.
which now begs the question...can it be reset without VAG-COM?
Don't think so.
I just used to ignore mine until "I" thought it was the correct time for a service, it only stays on briefly. |
Yes it can-that is how it is being reset, will look up how tomorrow if nobody else does it before that. There is also some trick how to reset it with knobs on instrument panel on some cars- might try to search on goggle.
Sorry, I read it as if it can be reset with VAGCOM in hurry. On some cars it can be reset without and on others not. Like pointed out below.
Currently 8less 2011 Q7 S Line 3.0TDI, 2016 Tesla Model S 90D 8 history: 2006 A8 Sport 4.2TDI quattro SOLD, 1997 S8, reached end of life with gearbox failure Last edited by ainarssems; 6th December 2011 at 09:55 AM. |
Well this isn't definitive, but:
http://www.audiforum.ca/showthread.php?t=34498 says: How to reset Oil & Service light without a diagnostic tool A8 1996-2006 Requires diagnostic tool. |
and Gendan offers this for resetting the fixed service interval without tools
http://www.gendan.co.uk/article_6.html#audi_a8_1994
D2 FL Q 2.8 V6 2002 Taxi(?) spec - no heated seats headlight washers etc. D2 PF Q 2.5 tdi LHD rear blinds and heated rear seats, Bose, 5 speed Tip, Servotronic, Pioneer AVIC 333,333 km Murdered on a P&O ferry 2012. Cat3 write off |
You have 1996 car right?
1.Connect to dash in VCDS 2. Select adaption 3.Use channels 5- oil change service, in 1000km, normally 15 for 15 000km 6- distance till inspection service 1, enter as above but normally 30 for 30k km 7 - time in x10 days till inspection service 1, normally 36 for 360 days 8 - time for inspection service 2 in days x10, normally 73 for 730 days The value in those channels will show distance/time remaining. Enter new value, test and save. This will be less then values above if service was done a while ago so enter appropriate value to as much distance/time remaining. Please note that distance used is in km not miles in all cars so do not forget to convert values before entering.
