Old 16th December 2011, 04:29 PM
RanjS8 RanjS8 is offline
Default Sat nav signal on preface lift cluster
Does anyone have a picture of what dis looks like on a prefacelift instrument cluster when the rns sends a turn signal
Please thanks
Old 16th December 2011, 04:37 PM
There's a rather pathetic picture in my drivers manual which looks familiar.
It shows an L-shaped arrow indicating the turn direction and the "distance strip" indicating how close - solid at the top and striped at the bottom.
Road name is below.
Old 16th December 2011, 05:27 PM
Default Dis picture
That's a fairly simple picture. Another question is the instrument cluster for the prefacelift different depending on whether u have sat nav.
Cos the dis on mine (non sat nav) looks pretty small.
Old 16th December 2011, 05:31 PM
Well I don't know for sure, but the display just uses the same space that the "open doors" diagram does for example.
Old 16th December 2011, 07:11 PM
Default instrument cluster dis
In that case the cluster must be the same...which is good news.
Old 16th December 2011, 09:34 PM
we can probably use etka to see if the codes for each cluster are the same or not Ranj
