Old 19th December 2011, 08:06 PM
Sub-Zero Sub-Zero is offline
Default Gearbox
Hi guys has anybody got a exploded diagram for a 2001 S8 gearbox I want to see what components are where on it as I've a leak above the front drivers side diff ? Gold oil which would suggest gearbox fluid !
Cheers fellas
Old 19th December 2011, 08:27 PM
There's one linked at the top of this thread:
http://forum.a8parts.co.uk/showthread.php?t=2964
Old 19th December 2011, 08:30 PM
Reffro Reffro is offline
I thought the trans fluid was purple and diff oil is gold.
Old 19th December 2011, 08:48 PM
Diff should be seperate oil.. and are the diff seals not a weak point?
Old 19th December 2011, 08:58 PM
The gearbox oil is gold I think diff oil is aswell I'm not to sure but it's deffo leaking gold oil above the front diff ?
Old 19th December 2011, 09:00 PM
No the gearbox oil is a real golden colour I'm not sure about diff oil reffro
Old 19th December 2011, 09:01 PM
Wink
Cheers adrian
Old 19th December 2011, 09:07 PM
Adrian looking at that diagram would you agree that gearbox oil can get through the rubber seal and into the diff casing ?Suggesting the seal is u/s ?
Old 19th December 2011, 09:26 PM
Having had all three output shaft seals replaced in the last 13 months, I would hazard a guess you have the same problem now. If so, it not a big deal, only a £130 job.
Old 19th December 2011, 09:28 PM
Yes, had one of mine done at the last service, not expensive (compared to the rest). Not sure which TBH.
I knew something was dripping, but wasn't sure what.
As it was landing on the exhaust and stinking I'd guess the one going rearwards....
