Old 12th January 2012, 07:06 PM
Amanda Amanda is offline
I regularly get this with the traction control light scrabbling off and on but mines for a different reason although I do find a better tire helps
Old 23rd March 2012, 11:02 AM
Curtis's Avatar
Curtis Curtis is offline
i have the same issue with mine,gets quiet bad and will make a thud and will stop. it also causes the rear tyre to squeal and loose traction aswel.replace inner cv's outers where fine all the control arms except curved arm are new so im bit lost on why im getting it.i thought it could be the play in the curved control arm or a warped bake disc bcos its alot worse than a s4 i have driven in
