![]() Once rotated to the release position it came off very easily. I had a moment of inspiration and remembered one of my "oldies" tools in the kitchen - a "BOA-CONSTRICTOR" designed to help remove difficult lids on jars. See: http://www.amazon.co.uk/Miscellaneou.../dp/B0001J0456 it even refers to use on cars there. ![]() It has a rigid plastic handle and a tough rubber strip that you wrap round the "lid" then feed back into a slot on the handle. Applying rotational pressure locks it firmly. Ideal for rotating the mounting pillar as it does no damage at all but gives a superb grip. ![]() As they say "Every home should have one" (and every car mechanic) Now I need to look at the power supply for the auto-dim version. I'd still prefer to take it off the sunroof (access comments anyone) but....... I've got all the floor mats out to dry the interior as stage 1 of dealing with the flooding, probably due to clogged evaporator drains. ![]() Last edited by HPsauce; 9th January 2012 at 12:18 PM. |
![]() Got the lights/sunroof panel off - unclip transparent bulb cover, remove 2 recessed screws by the bulb and it just unclips easily. ![]() (as described in the drivers manual, as I've just discovered ![]() But inside it, ignoring (for now) the wiring for the phone (mic) and sunroof controls there's a 5-core multicoloured lead to the interior lights. ![]() (there's also a thin, I think red/black, lead that meanders around with no obvious function/connection - sun visor mirror lights probably) I'll post up the colours shortly, but meanwhile I'm going to have a bit of an "investigate" with my multimeter on the interior light connection. Logic says you only need 3, not 5 - 12V, 0V and door open. ![]() (Unless anyone knows what they're all for and can save me the effort. ![]() Edit: The colours, from left to right are: Red with blue (or purple?) trace Green with blue trace Brown Brown with yellow trace Brown with white trace Last edited by HPsauce; 13th January 2012 at 11:06 AM. |
Results of investigations:
So no use for the mirror. ![]() The sunroof motor is more promising however; bit tricky to disconnect due to lack of space. Fat Red/white = 12V Purple/black also 12V Fat Brown = 0V Red/yellow = 12V when ignition is on (with a retaining delay I think), 0V when doors are locked. I don't want to disturb the "fat" heavy-duty cables to the sunroof, so I'll probably take 12V from the sunroof red/yellow and 0V from a screw (there's a couple of suitable holes in metal that test OK) or the lights (brown) using the dreaded Scotchlok's. No doubt some of you perfectionists will be squirming in your seats now. ![]() |
Job done, very pleased with the result. Works perfectly.
![]() Biggest problem in the end was actually getting the lead from the mirror into the space above the lights to connect it up, it's a bit tight and though I could get a big cable tie through to pull with the plugs kept snagging. In the end I fed it unterminated and fixed the plugs (just bullet connectors) once in place - very little spare wire to work with though. ![]() (I did take 12V from the sunroof and 0V from the interior lights in the end. ![]() |
And proved handy just now.
Already freezing outside, headed off to the station (3+ miles) and was stuck behind a big supermarket truck at 30mph on a narrowish country road. No possibility of overtaking anywhere. Some t**t in a big 4*4 caught us up and decided to drive as if I was towing him. ![]() |
Glad to see you got it working well.
![]() At some point, I'd like to replace mine with one from the C5 Allroad (probably on other C5 models). There was the digital compass option, pretty cool. ![]()
A couple of things I've noticed after rather more use:
1. The interior lights coming on (e.g. dropping off a passenger) make it go very dark very quickly. If you're using the interior mirror to check behind before moving off you need to wait briefly. 2. In the (admittedly very rare) situation of someone overtaking you on the motorway at night the darkest is actually as they get close and move out of your view. I think this is due to the direction the rear-facing sensor points in, i.e where the mirror is pointing which is obviously half-way between rearwards and towards your eyes, so significantly to the offside. Oddly I haven't noticed either of these effects on the similar mirror in my Ford Focus, though the rear-facing sensor on that is recessed below the mirror rather than behind the top of the glass. And being a hatchback there's probably more bodywork blocking light from overtaking vehicles. (it also has a handy "off" button) Last edited by HPsauce; 16th January 2012 at 10:12 PM. |
^^^ Interesting observation, HP.
This brings me to another issue - how do those with really dark tints on the rear (sometimes limo tint on the rear screen) fare with auto-dim (or rather lack of?) Because one could argue the rearview mirror doesn't suffer from as much "glare" as would be achieved with a stock rear screen. But that means the door mirrors won't dim either. Has anyone with dark rear windows suffered "glare" from their door mirrors as a result of the photo cell seeing less light from the rear?
Personally I've never really found glare from the door mirrors to be an issue on any car I've ever owned.
(and none have ever dimmed, just the interior one as on both my current cars) |
#30
Rear window tints will affect the accuracy of the auto dip mirror.
In the owners handbook, Audi even say that using the factory rear blind will affect the auto dip mirrors (where fitted)... ![]()
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
