Old 17th January 2012, 12:19 PM
Thanks folks - got to the car, which turned out to be a low miler MG ZR, and it appears an interior light was left on when it was last used hence why it was flat as you like. Got the leads on and left it for quite a while, then experimented with the ignition and the fuel pump primed with plenty of enthusiasm. Gave it another 20 minutes with mine idling and then upped the revs - it started 2nd turn of the key and purred away quite happily.
Left them to drive down to Halfords and get a new battery - although it was quite a funny thought that they were all going to have to get in via the drivers door as the passenger one and boot were both still deadlocked! So that's baby into baby seat, pushchair on back seat, and a climb across the seats for one adult lol
Old 17th January 2012, 12:28 PM
If it's anything like my father-in-laws old small Rover 400 (sold last year, he no longer drives) the drivers manual tells you how to resync the deadlocking after restoring battery power.
(had to do it a fair few times in the past, takes only seconds)
Old 17th January 2012, 10:08 PM
Adrian. Glad you got it started and everything is OK with yours.
This thread raises some issues, and as we A8 drivers would like to display our Samaritan qualities, when called upon, it would be good if we could get to the bottom of the risks involved in providing that vital spark to a fellow motorist.
As far as I can understand the risk in jumping to a dead battery is to the leads, they melt. So it makes sense to connect and run the donor for a while to get some juice into the recipient before turning it over.
If you could connect the running car to the dead one with massive leads, then surely the draw from a piddly Rover turning over would be loads less than the A8's own startup.
There must be some other reason why jump starting can mess up the ECU etc. Anyone know why this might be?
Incidentally I believe the connection sequence is. Get donor car running. Connect the + on each car first, then connect the - to an earthed (not - pole on the battery) part of the donor car, followed by the other end to an earthed (not - pole on battery) part of the donor.
Keeping the earth connection away from the battery reduces the risk of igniting the hydrogen/oxygen given out by a charging battery.
Old 17th January 2012, 11:48 PM
Nollywood's Avatar
01) Voltage spikes.
02) Current surges.
03) Short-circuit in dead car.
04) Short-circuit or high-resistance in dead battery, due to damaged plates.
I would invest in a set of jumper-cables with built-in surge protection. A lot safer for the donor car's semi-conductor electronics. I had a set, lent them out to a buddy, and never got them back. They cost me £60 at the time.
Old 18th January 2012, 06:23 AM
graynada graynada is offline
Whilst I can understand the advice to minimise sparks in the vicinity of possible explosive gases, if you connect the jump leads to anything other than the battery directly you will increase the chances of passing high current through something sensitive. Connecting battery to battery allows your battery to directly supply current to the point where their battery would provide current for starting, without going through any other circuit on your car, or theirs.
Unless you have had a battery on charge for some time in an unventilated area the chances of a build up of significant quantities of explosive gases I would say will be minimal and can easily be countered by opening your boot and their bonnet for 5 mins before attaching the leads.
Good quality leads are a must, heavier gauge the better.
Old 18th January 2012, 08:31 AM
Post
I took the practical view that when the ignition was switched on there was clearly enough juice getting through for the fuel pump to prime as normal
As for connecting to anything other than battery terminals, I'm of the view that if it was necessary then a point would be provided. I know on some Japanese and German cars it is specified in the manual
My neighbour recently started his rover 75 using his dads Mazda 6 - both V6 - and that had sparks etc flying about with cheap jump leads. Since mine was clearly not straining to provide power I didnt feel too worried - I did also turn off all internal electronics I could to reduce load and risk
I'm usually more worried about frying immobilisers on dead cars from past experience
My leads are very chunky for 12v use - unfortunately the clips are mainly plastic so 1 broke when I dropped it on the floor.....
I've had a truck battery blow up on me when jump starting another so I do understand care is extremely important when dealing with batteries
Need to find some surge protected leads - never seen any! Mind you this is the 1st time I've used mine in 10 years.....
Old 18th January 2012, 10:17 AM
If you're going to spend that sort of cash on a piar of leads you'd probably be better off with a portable starter. Like or similarhttp://www.maplin.co.uk/portable-jum...mpressor-49038
