Old 18th January 2012, 09:39 PM
If the car is in one piece, pull out the TCU, start the engine and you'll find out...
Old 18th January 2012, 10:34 PM
Nollywood's Avatar
There's no TCU, the connector is just zip-tied to one side, and the connectors to the tranny are hanging free, for now.
I've been on it since Monday, just isn't revving past about 6,200 rpm, it feels like a soft-cut rev limiter. Prior to the manual tranny swap, it ran great.
Old 19th January 2012, 01:04 AM
Have you changed coding?
Old 19th January 2012, 02:12 AM
Nollywood's Avatar
^^^ No, coding hasn't been changed.
Old 19th January 2012, 05:32 AM
So just change coding and you will see if it is because of coding or something else. It's less then 5min job that can be done with the £8 e-bay cable.
Codings are automatic:
with ESP 03373
without ESP 03273
and manual:
with ESP 03313
without ESP 03213
First digits may be 04 on later cars for MVEG II emissions standard
Old 19th January 2012, 12:16 PM
Nollywood's Avatar
^^^ Thanks bud.
Old 19th January 2012, 07:43 PM
71camaro 71camaro is offline
On Quattroworld, to view a complete thread click "all messages." It's located at the top left of the reply you're reading.
Old 19th January 2012, 07:59 PM
Nollywood's Avatar
Thanks bud, that's a great help, will go there now.
Old 23rd January 2012, 12:50 PM
A8 Doc A8 Doc is offline
Sounds a cool conversion.
If you're codes dont match above, post up the codes in your engine controller and we can have a go.
Old 23rd January 2012, 05:20 PM
Nollywood's Avatar
Thanks Doc.
