Old 21st January 2012, 11:30 AM
Default High level centre brake light bulb replacement
My car was at the garage having some work done today, and whilst they were driving it I noticed that 2 of the bulbs in the high level brake light have failed. I had a quick look but cannot immediately see how to remove the light to replace the bulbs.
So todays question, how do you remove the unit to change the bulbs and what type of bulb is needed for replacement.
Old 22nd January 2012, 02:31 AM
Bulbs are - 4 No. of
part No. N 017 753 5
W5W-12V5W
and are £1.83 each
It looks like the housing needs to come off (screw as shown) and then youn can access the bulb holder. You may need to unscrew the housing from under the parcel shelf in the boot
Name:	Rear HL Brake Light.jpg
Old 22nd January 2012, 07:35 AM
Thanks, I think your right. I did look in the boot, but perhaps the screw is located in hole rather than the on the surface. At least I now know where to look, now to get some W5W bulbs and change them all.
Old 22nd January 2012, 11:14 PM
jayzee jayzee is offline
Why oh why couldn't Audi have used velcro for the cover?
Yeah baby!!
Old 23rd January 2012, 08:00 AM
I don't remember it having screws in it when i changed a blub in mine
Old 25th January 2012, 05:50 PM
I now have the new bulbs, and went to have a go this evening. There are 2 holes beneath the light when looking in through the boot, but they don't appear to have screws in. They are quiet deep, so I inserted a screwdriver and cannot feel a screw head in there to undo.
Dezzy, do you recall how the cover comes off on the rear shelf.
edit. think I answered my own question.
http://www.audipages.com/Tech_Articl...rakelight.html
in the US its called a Hat shelf.
Old 25th January 2012, 06:16 PM
And I have now changed the bulbs, took just a few minutes once I knew how to take it apart.
Old 26th January 2012, 08:46 AM
I know it's too late now but it just pulls off forward
Old 26th January 2012, 09:55 AM
Is it the same if you have a rear blind?
Old 26th January 2012, 01:23 PM
Yes, because I have the rear blind. it just pulls forward still but because of the rear blind as you pull it forwards you lift slightly to get over the blind.
