Old 27th January 2012, 12:25 PM
Internal resistance too high probably refers to heater element in lambda sensor. This means that heater element is not working and it takes longer for it to heat up and start working but it is still working. So no need to change it in hurry unless you mostly do very short trips.
Part number is 077 906 265 J for V8
06A 906 262 BF for V6
Not sure if it is the "easier" one, on PF it is pretty much about the same
Old 27th January 2012, 12:42 PM
ADU UR quattro ADU UR quattro is offline
I had mine done lastyear, it was straight forward job.I should have replaced both banks, at the same time.(now the other bank is throwing up the error code).If I remember correctly it was underneath the car near the cat on passenger side.
Old 30th January 2012, 09:25 AM
johnds8 johnds8 is offline
Hi Guys,
Cheers for the info.
They are all over ~100k now so about due for changing.
May aswell get them done and then it's more pennies for the right foot as opposed to an old sensor!
John
