Old 31st January 2012, 09:39 AM
47p2's Avatar
47p2 47p2 is offline
Thanks snapdragon, the 'can of worms' syndrome opens when you start trying to save a few shillings of ATF by not buying from the dealer.
I have a Range Rover which I changed the ATF, the dealer charges around £16 per litre for the ATF but with a little research I managed to obtain a 20 litre drum for just under £60 which will allow me a few oil changes.
I might do a 'How to' when I am changing the ATF. That should help others and save them paying over the odds for garages to carry out the work
Old 31st January 2012, 09:58 AM
audipages.com has a procedure for the D2 gearbox which is very similar... I could also see what ETKA has as a procedure for it.
Old 31st January 2012, 10:08 AM
47p2's Avatar
That would be very helpful, thanks
Old 31st January 2012, 11:45 AM
Can't get the damn thing to create a PDF at the minute, but the procedure seems to be the same as the audipages.com one, just make sure you get the correct bits for yours. Seems to be about 8-9l of ATF in there.
Old 31st January 2012, 11:53 AM
The fluid is made by Shell, but not marketed by them, only available through Audi, ZF, BMW
I am pretty sure ZF Lifeguard 5 that goes in D2 boxes is LT 71141 made by Esso, not sure about newer ones but I would expect them to be Esso as well
Old 31st January 2012, 02:14 PM
The ESSO/Exxon is another golden fluid, but not used in any D3 application AFAIK.
It is no longer made, but Exxon/MOBIL market a red all purpose ATF which is supped to replace it and is marked as such.
I don't think these fluids are specified for the D3 auto boxes.
I would stick to ZF or dealer fluid, at least until the D3 is old and on it's last legs.
Old 31st January 2012, 09:23 PM
47p2's Avatar
I've found Lifeguard 6 or Shell M-1375.4 which are supposedly the correct fluids, but will need to do a bit more research before making a purchase
Old 9th February 2012, 07:48 AM
47p2's Avatar
Interesting article on the ZF 6HP gearboxes here
Nite Blue 3.0L SE Quattro
