Just got mine and i got ABS light comes on some time....whats the cure..new pads
Handbrake doesnt work....how do i fix it... Please "Jim fix it for me" |
Handbrake - On my old A8, I needed to change the handbrake cable, I think there was also a seized caliper which didn't help. Not to costly, got A8 parts to send the cable and caliper to me next day and a local indie to fit.
ABS - This is most likely a sensor. First of all, you will need to VAG COM the car to find out which sensor is playing up. If I remember correctly, there are four sensors. VAG COM will bring back something such as 'FRONT RIGHT SPEED SENSOR' take the ABS sensor out and clean it, this should do the trick but in my experience it will eventually fail, mine did last another 4/5 months though after a clean (wire wool & water - You may want to use WD40 if the dirt is quite stubborn). I managed to get a new one for free from a bloke that crashed an S8 in my area. They are a doddle to fit. You just need to remove the lining under the arch and unplug the old and fit the new. I wouldn't recommend driving with no ABS, if you have to brake hard. It could be dangerous, best to get it sorted. Hope this helps buddy ![]() EDIT: See here on how to remove/clean dirty ABS sensor.
2009 Audi RS 6 Saloon V10 - 420mm Ceramics, Keyless, Soft Close, Adaptive Cruise, Glass Sunroof, Blinds, Twin Pane & UV, Freeview & DAB, High Beam Assist, MTM bits, Audi Exclusive Bits, MRC, Milltek, GYEF1 ASY2's, Bluetooth streaming music to AMI mod - 753 PS/1021 NM 2016 Audi S3 Saloon, Sepang, S-Tronic - B&O, Tech Pack etc... Company Car 1995 Audi A8 4.2 V8 quattro Sport - Bose, Solar, Blinds Last edited by Conan_the_Librarian; 13th April 2009 at 06:52 AM. Reason: Fix Link |
If my memory serves me correctly the handbrake replacement process is quite fiddly. It involves removing the propshaft and other bits to route the 2 new cables.
I'll see if I can find the process when I get Elsawin to work! ![]()
It's working!
![]() Brake System Removing and installing handbrake cables Removing
=> 8-cylinder Engine, Mechanical Components; Repair group 26
![]() Mark the position at which the propshaft is bolted to the rear differential.
Pay special attention to the following on installation:
Are these auto adjust, or can they be tightened?
Mine is getting pretty loose now and is definitely worse since I changed the rear discs and pads. |
They are auto adjust. Only need adjusting on fitting of new cable to ensure they are not on to tight.
New pads mean that brake calliper doesn't have to move as far to engage so a stretched cable will need to have more handbrake leaver movement. If it ain't holding you on a steep hill it's time to replace. Not to expensive. GSF do the cables for about £30.
Thought so.. That's number 3 then
![]() Bloody puncture.. Bloody Windscreen.. Bloody H/B cable.. Bloody love driving it though ![]() |
* ‒ → Loosen the adjusting nut for the handbrake cable using special tool -3343-.
* ‒ Take the handbrake cables off the compensating bar. Any idea what the special tool for this is? I'm assuming it'll be in a decent mechanics standard kit |
The "special tool" is in fact a 14mm socket on a long extension bar - look back on this thread to conans earlier post and there is a picture of it
Ah.. but but for the 'complete tool' you need to go to the local Audi garage
