  #32
Old 10th February 2012, 06:08 AM
I had No luck with WD40, Plus Gas, burning torch or air hammer, nothing moved mine. I've ended up getting replacement hub carriers
Why new hub carriers? You could have drilled them out if everything else fails.
Also the problem with WD40 and other penetrating oils is that it cannot penetrate deep in short amount of time and leaving for longer most of it runs off and rest evaporates. What I do is wrap it with rags or paper towels soaked in penetrating oil and leave it overnight to soak.
ordered up the 3.7 ones and payed for them they will be with me tomorrow, just the control arms now, thanks for the info guys its been a massive help, hate spending money on the wrong parts, i confirmed that the 3.7 are the same across the bord with all 40v facelift models
will get the arms ordered now and get to work on them on monday morning thanks again for all the help my round at the next meet i think
Check handbrake levers that they are moving freely on new calipers and maybe take apart and clean anyway before fitting them.
