Old 14th April 2009, 08:33 PM
Well, A little update....
It seems that the old Ford diesels are somewhat robust, and even though the cambelt went (which is apparently common) folks recon that just buy a new belt, replace any new bits and away we go...
So, I've taken the tops off the engine, which is a 5 minute job and found 1 broken rocker, and 7 bent push rods....
So, I bought a new timing belt, water pump, tensioner, push rods and a whole rocker set, delivered including VAT for less than £130... Wow these ford things are cheap.
Anyway, I fitted the belt, pump, tensioner etc over the weekend and the rockers have just arrived so I can fit them tomorrow.
But, so far, looks like its all recoverable... which is a amazing....
Still need a new zorst though, but I can get a brand new one for £30
Old 14th April 2009, 08:35 PM
If it starts and runs first time it will be a bonza result!
Old 14th April 2009, 08:40 PM
I've already cranked it over with the started and it sound sweet enough, confidence is high
It was quite amusing removing the radiator to gain access.
2 10mm bolts and it comes out lol. And its roughly the size of my RS6 intercoolers
