Old 23rd February 2012, 07:56 PM
Originally Posted by A8 Doc View Post
But no comparison really. Miss it badly.
Yes.... I suggest some strong medication, and common sense will resume shortly...
Old 24th February 2012, 12:43 PM
Default Looking more doubtful....
This morning wasnt going well. I was tired, and frankly ACC had done a good job so I sort of left it to it.
But it was going pete tong, badly. 2 urban Journeys through Harrogate traffic, 1 with a cold engine, then relying on ACC to get a good MPG had seriously chewed some fuel.
Here we are at Trowell, half way there with a pityful MPG of 43, nothing like the near 50 I need.
Worse still, the Range + trip now equals less than 900... Yikes.
So cafeine to the rescue, and onto plan B. An 18 wheeler....
Trundling along at 55 mph is not easy. Trucks dont do 55mph, they do almost anything between 50 and 60, which is completely unnoticed when hurtling past at traditional motorway speeds - They all seem to be going the same speed of slowness.
Big trucks have to abide by the 40/50/60 rule - 40 on A roads, 50 on Dual Carriageways and 60 on motorways by law.
Some are governed to 56, presumably for economy, whilst heavily laden ones slow down to 50 up hill, and hoof it down hills to get a shuffle on.
Then, the drivers paid by the hour (or worse still on overtime) just trundle along slowly.
So, dodging the trucks was a nightmare. Theres only so many times you can be subject of a drawn out, 3 minute, 4 mile overtake manouver before you start to feel a little guilty.
I'm also concious that if my speed drops under 55mph, the torque convertor unlocks, which I'm convinced is less economical as the engine is free to rev far more than I might otherwise need to.....
So, back to the plan.
If I could find a big truck, driven enthusiastically by someone clearly getting a shift on, it would regulate my speed, get rid of the painful overtakes and as a bonus would give me something to slipstream.
Here comes into play this lovely tri deck transporter, nice and wide and clearly looking to make a punctual delivery. Full of Skoads, VW's and Audis too. It was surely meant to be.
ACC was off, and switched to manual throttle, including RSI of the ankle and premature wear of the heel section of the drivers floor mat, but hey, anything for science eh ?
And so I plodded with these new plan working wonders. Had to switch trucks at the M1 / A42 split as my VAG transporter stayed on the M1, but I found a nice box trailer to sit behind into Birmingham..
Whilst plodding along at my found comfort speed, I did some basic (and rather alarming) sums.
If you have 90 litres of fuel, and can drain every drop, then to do 1000 miles you will need to achieve an average of 50.44 MPG. An average. Sheesh. Wish I'd done that maths before starting.
On the plus side, on the same basis, 900 miles would require only 45.4 MPG - which seems really quite easy in contrast.
Anyway, arrived at birmingham & parked up with the following numbers:
So, I pulled the MPG up by 3 MPG, which is very good. I must have been doing more than 47 to pull it up from 43.8, so my new plan really did work. The 5 mins of urban travelling through Brum brought the range down a bit, but still 330 + 536 = 866 miles total.
Tonight will be tricky - Even if I get through the Friday night lottery that is the M6, I then hit heavy Friday traffic on the urban roads of Harrogate. I'm also in a 'rush' as I'm going out tonight....
ID:	2854   Click image for larger version
ID:	2855   Click image for larger version
ID:	2856   Click image for larger version
ID:	2857   Click image for larger version
Old 26th February 2012, 08:08 PM
So, after various regular Friday traffic hold ups, we're home, and after the urban crawl through Harrogate we are looking like this:
So, 677 miles done. 150 left, albeit falsely low due to the recent urban journey......
Note still got a fraction under 1/4 tank left, which after 677 miles aint bad at all really....
1000 aint looking likely, 900 is gonna be tough still.....
130 miles to Brum tomorrow should see me at 800 miles. It'll be interesting to see the fuel state of play at that point...
ID:	2874   Click image for larger version
Old 27th February 2012, 04:39 PM
I'd have bet no chance from the start if the trip computer is anything like the D2. Mine says that I have a range of around 500 miles when I first fill it up, but as it gets further down the tank this drops quite quickly. By half full, the range plus miles travelled is usually around the 450 mark but, by the time I fill up, I'm often lucky to be above 400. So around 100 miles gets 'lost' to the computer along the way!
Old 27th February 2012, 07:13 PM
What might help everybody is the fact that Morrisons supermarket are currently running a 15p a ltr off the pump price offer (they already are the cheapest in our area (132.9)) from the 23rd Feb to the 4th March. You need to spend £60 instore in that period and can redeem up to 11th march.
Old 27th February 2012, 07:31 PM
My car only drinks Shell V Power or Tesco Moumentum which is 99 RON, sometimes BP Ultimate. I got a 10p off a litre voucher from Tesco which meant I got £8 off my £115 tank. Every little helps.
Old 27th February 2012, 08:24 PM
Shell recently sold off one of their petrol stations in Swindon and kindly gave me a load of 10% off vouchers to use between now and April when I fill up at their other one - so happy days!!
Old 27th February 2012, 07:41 PM
Yep. Mine does exactly that, and so too every single car I've ever had with a trip computer.
Never understood why this should be so. In fact range should improve as the fuel load drops... But the reverse happens.
Keep at it though. Its a great thread
