Old 20th April 2009, 09:32 AM
ulfilias ulfilias is offline
Hi There,
The standard 10gig or 20gig drives are pretty good for MP3...You will get the same amount of tracks on as a similar size mp3 player....Don't know what size your creative is, but certainly if you hack it you will be able to beat it - Hacking is easy from what i recall- You use the existing drive to get a code from (there is a prog to do this) - Swap drives (remove 4 screws, a connector, fit a new large 2.5" laptop hard drive) - Flash the new drive with the code (more progs) - Can be done in an hour or so.
Depending on which RNS you have, the D doesn't show track names but i belive the E (later one) does. The kenwood has voice prompts which are fairly cool. don't know if the audi does.
cya,
Lee
