Old 6th March 2012, 01:29 PM
Fluid was changed at the last service, when the rear pads were fitted.
(along with a load of other stuff that was done - t'was expensive!)
Also the brakes were fine a couple of weeks ago when I last drove it.
Old 6th March 2012, 05:15 PM
S4Phil's Avatar
S4Phil S4Phil is offline
How much of an 'inspection' did he make?
Check:
Brake flexi hoses
Brake pipes (condition and for leaks)
Calipers for leaks
ABS module for leaks
Old 6th March 2012, 05:20 PM
It was only a quick look with a torch - no ramp available.
I've got it booked in for investigation this Friday.
(where it was last serviced - Fontain in Iver)
Old 6th March 2012, 05:33 PM
47p2's Avatar
47p2 47p2 is offline
Flexi hoses would be the first thing I would check, have someone press the pedal whilst someone checks each hose for bulges
Nite Blue 3.0L SE Quattro
Old 14th March 2012, 08:41 AM
Well, the latest news I have is quite concerning.....
Having replaced the master cylinder and while working on bleeding the brakes they have found:
Both front brakes INNNER brake pads have lost the material! Only backing left, the blocks have come off (not worn away).
Now these pads were replaced about 2 years ago by this same garage, and I've not done a lot of mileage since. So, here are my first thoughts:
1. Should they have noticed this while checking for problems?
2. Would the pedal be "soft" as a result of this or could I genuinely have had a master cylinder problem as well?
I feel an interesting "discussion" coming on with the management....
Old 14th March 2012, 08:49 AM
Definitely an interesting discussion... While the pads could simply have failed, it could be a sticky piston causing them to wear prematurely.
Either way, they should have spotted that long before suggesting any other parts!!
Old 14th March 2012, 08:51 AM
They haven't worn, the pad material has gone totally - broken away from the backing material.
Cheap chinese fakes maybe?
Old 14th March 2012, 08:53 AM
Can't understand how they can consider they've done a proper investigation if they missed that until they were putting it back together
If they don't agree the master cylinder wasn't faulty ask them to give you the old one and get it checked professionally. Make sure they don't have an opportunity to fiddle with it first....
Otherwise ask them to refit the old one and pay for replacement pads
Old 14th March 2012, 08:57 AM
Any idea on where I could get that done?
Old 14th March 2012, 09:49 AM
graynada graynada is offline
I'm surprised it wasn't making a horrible noise.
