Old 8th March 2012, 09:33 AM
Here you go.. This is from the audiforums.us thread. Someone documented their retrofit. The ELSAWin documentation is a bit crap.
Old 8th March 2012, 10:13 AM
47p2's Avatar
47p2 47p2 is offline
Thanks for that Richard, makes perfect sense now.
Dave, I have emailed you re the hinge alignment, thanks
Nite Blue 3.0L SE Quattro
Old 8th March 2012, 01:26 PM
47p2's Avatar
I've now removed the opener which is a simple two bolt job. It's the original motor part number 4E0 827 852 E and the new motor which I believe is the latest upgrade is number 4E0 827 852 H. I've also seen part number 4E0 827 852 G which is another upgraded opener, so it looks like Audi have been having problems with the openers. Just waiting on the new part arriving to fit it.
I also decided to remove the struts and give the hinges another dousing of oil, I couldn't believe how heavy the boot lid was without the struts.
Old 12th March 2012, 01:35 PM
47p2's Avatar
New boot opener arrived today and if the old one was easy to remove it was a little more awkward fitting the new one. I had to lie inside the boot and get into positions I never knew were possible at my age, the biggest worry was incase I pushed the motor up too far and made a ding on the rear wing, but with a little care I eventually managed to slip it into position and bolt it on. The bad news is interior release button is still not working so I will have to investigate that further, I do wonder if it has a separate fuse somewhere? The good news though is the boot opens and closes no problem
You can see from the picture Audi have made the motor much larger (possibly the old motor was not powerful enough to lift the boot lid) and the outer casing is now made from alloy cast instead of plastic
Old 12th March 2012, 02:28 PM
47p2's Avatar
Interior release button sorter, not that there was anything wrong with it
The key position on the boot lid was in the incorrect position to allow it to open.
Old 12th March 2012, 02:32 PM
Ah, the old rtfm fix....
D2 had the same 'feature' iirc - For security..... Stops the boot being opened even if someone smashes the window, and manages to open the door....
Old 12th March 2012, 05:01 PM
christhompson's Avatar
Very possibly on all Audis as I know this from A90Q, CD100Q, Coupe [not splendid type], plain 90, and 100LS all that way back.
